Dave, I've been following your pre-heat posts and have a few questions.
A while back I calculated my 80 gallon waterheater needed about 17 Kwh to raise the water temp from ground to 130 or so degrees F. With a 3000 watt element, that's about 6 hours...
If you have slightly lower ground temps. and raise to 150F., you might need 20 or so Kwh.
Have you thought of a separate air or water resistance dump when the elements reach the temps you set? During the fall, winter, and spring months there will/ might be times that you need to dump the extra power to not blow the waterheater safety.
Looks like you may offset all/ most of your hot water needs once you integrate your setup! Just trying to see what you have planned for the days that winds stay steady in the 20 to 30 mph. range, happens even hidden in Souhteastern Pa. here... :-) Gary D.
