Most likely have came across some of my posts for designing a 24' 10kw wind turbine.
Issue to solve: Blade damage due to excessive yaw rate change, caused by storm, gusting etc. Consistently I heard the most frequent damage occurs during too fast turning of the wind gen.
Tail size is not consistent from the various post I can find. So, I plotted them and made a best guess. Came up with rules of thumb. Comments welcome. (table under REC what I could find:)
Tails of thumb:
Tail Length is blade dia / 2 or longer (Very consistent recommendation)
Tail area is blade area / 16 (smaller if length is longer. Not consistent data)
Tail force equation and included conversion factors.
Fd = Cd 0.5 * p * A * v^2
Fd = The drag force measured in N (Newton). 1 lbf = 4.448222 N
Cd = The drag coefficient, measured in N/ m2, i.e. the drag force per square metre frontal area of the object shape. Assumed flat suffice is = 0.9
p = The density of the fluid in kg/m3. Dry air at sea surface level at 15C = 1.225 kg/m3.
A = Frontal area of the object in m2. 1Ft = 0.3048m
v = Relative wind speed in m/s (assumed tail not moving, force less if it is) 0.440704m/s = 1mph
Force in lbf. The low speed numbers below are smaller than expected. Anybody want to check?
Sorry about the table, after messing with if for a hour I am done.
Blade Tail REC 5 10 15 20 25 30 40 50 60 70
dia Area Area
8 50.27 3.14 5 0.18 0.72 1.63 2.89 4.52 6.51 11.57 18.08 26.04 35.44
9 63.62 3.98 0.23 0.92 2.06 3.66 5.72 8.24 14.65 22.88 32.95 44.85
10 78.54 4.91 5 0.28 1.13 2.54 4.52 7.06 10.17 18.08 28.25 40.68 55.37
11 95.03 5.94 0.34 1.37 3.08 5.47 8.55 12.31 21.88 34.18 49.22 67
12 113.1 7.07 12 0.41 1.63 3.66 6.51 10.17 14.65 26.04 40.68 58.58 79.73
13 132.73 8.3 0.48 1.91 4.3 7.64 11.94 17.19 30.56 47.74 68.75 93.58
14 153.94 9.62 10 0.55 2.21 4.98 8.86 13.84 19.93 35.44 55.37 79.73 108.53
15 176.71 11.04 0.64 2.54 5.72 10.17 15.89 22.88 40.68 63.56 91.53 124.58
16 201.06 12.57 10 0.72 2.89 6.51 11.57 18.08 26.04 46.29 72.32 104.14 141.75
17 226.98 14.19 0.82 3.27 7.35 13.06 20.41 29.39 52.25 81.64 117.57 160.02
18 254.47 15.9 0.92 3.66 8.24 14.65 22.88 32.95 58.58 91.53 131.81 179.4
19 283.53 17.72 1.02 4.08 9.18 16.32 25.5 36.71 65.27 101.98 146.86 199.89
20 314.16 19.63 1.13 4.52 10.17 18.08 28.25 40.68 72.32 113 162.72 221.48
21 346.36 21.65 1.25 4.98 11.21 19.93 31.15 44.85 79.73 124.58 179.4 244.19
22 380.13 23.76 1.37 5.47 12.31 21.88 34.18 49.22 87.51 136.73 196.89 268
23 415.48 25.97 1.49 5.98 13.45 23.91 37.36 53.8 95.64 149.45 215.2 292.91
24 452.39 28.27 1.63 6.51 14.65 26.04 40.68 58.58 104.14 162.72 234.32 318.94
The force in 5mph wind is very small, thus deterring tail size. (cut in speed for your system should be used.) Take a look at 10', 70mph, force is 55lbf wow! Whip that baby around!
Solution: Tail is mounted to hang down from the support pipe. The attachment is a pipe in pipe to make a pivot or use bearings. The tail is made to swinging, I call it the floppy tail. Will be swinging a lot so make a good bearing of some type. Plastic, bronze, bearings of some type.
Head on winds will not effect the tails performance.
Low winds will not swing up so wind can push tail and do its yaw function without change.
Medium winds will cause the tail to swing up some, limiting the force it can push.
Gusting winds the tail will swing it up so, little force is imparted in turning the wind gen, thus protecting it from excessive yaw rate changes. Response is immediate. Noting to break. No electronics.
Secondary benefits the tail can be made with lighter, thinner materials than before.
Furling systems depent on tail weight, need to keep weight the same. Yet, Tail can pivot for protection.
Ok, experienced wind turbine builders what do you think?
Anybody want to test it? Have no idea when I will get to test.
Have fun,
Scott.
