I've got my magnets mounted to the saw blades, the blades fitted with bearings, the 'jacking' screws fitted and adjusted, now all I have to do is figure out a temporary mount for a single coil (105 turns of 20ga) as I'm not steady enough to hold the coil in place (besides the obvious magnetic attraction to the coil).
So, what kind of setups have you guys done to do this?
BTW, I was able to hold the coil in place and spin the rotor, got as much as 30mv peaks but I'm guessing (hoping) I'll get better once I can get the gap down and the speed up to 100rpm or so. Doesn't sound like much, but it's my first 'generated' power from this model.
