"The ground stays about 55 degrees F year round."
Maybe where you are. The ground where I am stays a little over 70F and when I lived in Ohio it was about 57F. In Northern Ontario it was 47F - IIRC. As these are the only places I have actually observed, they are the only ones I know reliable.
At this time the least expensive way to air-condition is probably grid power. With tax credits and other 'artificial' accounting methods there may be some way to use wind or solar to an advantage.
What won't work is spending a few thousand - or tens of thousands of dollars, to dig a large basement to find out the ground temperature is 68F and it takes 3 hours for the basement to cool after the door gets opened.
The new refrigerators and freezers have had a lot of research going into efficiency. SunDanzer (I think) has a DC frig that is only a little more efficient than the most efficient 120V (here in "The States") refrigerators. The cost difference will more than purchase the PV panels to make up the difference and buy an inverter.
That said I THINK there is a way to power a car type compressor with wind and get the 'cool' down a good sized tower without many problems. It would not be inexpensive to try and would be frustrating to build the first few. One would need refrigeration experience, horizional wind turbine knowledge, good mathematical abilities, good reasoning skills, access to machine tools and abilities and probably need a good sense of humor just to attempt it.
It is not practical to start a projects combining unproven designs. Such things are prone to failure. Unless one can clear the first hurtle there is no way one can finish the race. Before one started a project using a VAWT, one should emulate one that is working as a start.
Good luck, do research, design with known parameters, use proven technology where it can be used and success is easier to achieve.
