I really like this solar powered idea. I might experiment with that when the weather gets better. However I need to make mine work first! I'm looking for any thoughts here. I just installed my system this past weekend, had a hell of a time getting the outdoor information to be sent to the in-house unit. Then all of a sudden, it started working and all was good. This was by mid afternoon, went to bed just after midnight all was good. got up the next day and back to no outdoor info at all, only the indoor stuff. I'll list what I have done.
-Brand new Lithium batteries, yes they are at full voltage under load
-Tried base unit on batteries and adapter (with batteries removed)
-I have tried the transmitter within inches of the base, a few feet, and up to maybe 30 feet away still no transmission.
-Tried starting from scratch again on the powering up of things, still nothing.
-Tried the reset button on the transmitter
- verified that I have the correct item (rain sensor, wind sensor) plugged into the correct sockets
-At this time the transmitter is mounted outside on a wooden window frame and the base is on a table about 5 feet away inside in the same room
Everything to do with indoor info appears fine, was even forcasting now. Has anyone had this problem to know if is the transmitter, or the base not working. I have a feeling from the short time it was working, that the base suffers from the "software mis-calculations" with the windchill. I haven't gotten home in time to call Thermor because they are closed, so thought I'd give you guys a shot in the mean time. :-)
