Thank you flux, that's execllent input. My site is not very turbulent (clean in all directions for 1000 ft except for the southeast where my house and some trees are situated, they are 150 ft away from the tower. The tower is on a hill, and it's 60 ft high, the house projects about 10 ft above the top of the hill, the trees a little bit more.
A yaw damper is a good idea. The main reason why I'm worried about coriolis is that I have never built blades before, and even if the little test blade I have made seems quite strong I figure the attachment point near the root (where the foam ends and the 'hard' stuff begins) is the weak point. I intend to use some 'fingers' to ease the transition, but my worries remain.
In the beginning I intend to run the machine with a very light setting on the spring that controls the governor, to make sure everything works and to keep RPM down, then as I get more confident I'll crank it up, eventually limiting the rotor speed to about 270 RPM. The blades can be turned 20 degrees, initial angle of attack is 4 degrees, so with the governor at its maximum the tips will be at 24 degrees attack, the root will be at 44.
Worm gearboxes are expensive, I checked into that and they go for about $180 a piece, and are pretty heavy. That's why I was looking for alternatives, a buddy of mine has a chain drive active tail on a 3Kw machine, but it's very ugly and needs a lot of maintenance (that chain is exposed to the weather).
I'll have a 'short out' switch at the bottom of the tower, my 2 Hp driven lathe will cut out at even the lowest gearings when I short the windings directly, but I'm not sure how that will work with 60 ft of cable attached to them. They are pretty big blades after all, and I really wouldn't want to fry my windings.
So, passive with a pump as an oid damper is a good alternative to an active tail, the only possible failure point that's got is if the pump loses it's oil but you will notice that soon enough because of the increased speed of rotation.
I'm trying to design this thing in such a way that parts will be easily manufacturable by whoever wants to make one, the basic idea is 'raw materials in', 'windmill out'. No exotic stuff, other than the blades, and they could be replaced with a wooden alternative without a problem.
That's why I don't like gearboxes and such, specific brands of driveline components are not always easy to get, it was hard enough to pick bearings that are available everywhere.
A power steering pump on the other hand has almost the same design everywhere, even between brands they are sometimes interchangeable, so I don't see too much of a problem with that.
