The most accurate way to determine the number of turns for your coils.
Go ahead and build your 2 magnet rotors and assemble them without the stator coils. Spin the magnets up to your desired Cut-In speed, around 200 rpm. Then wind test coils and put them in the Air-Gap where the stator will be. Make plenty of electrical measurements of the coil. Wind more test coils and test them. Once you get a test coil that performs like you want it to, then you just duplicate that coil until you have enough to build your generator.
Doing it this way will almost guarantee that your generator will function like you want it to. Mathematics will only get you into the ballpark.
