Author Topic: coils  (Read 2790 times)
ricksure
coils
« on: April 10, 2007, 01:02:15 AM »
After determining number of magnets to coils and number of turns of wire, is the
coil thickness done by trial and error? I would guess after building a few it
gets easier to "guess".  thanks for any insight Rick.
« Last Edit: April 10, 2007, 01:02:15 AM by (unknown) »
Re: coils
« Reply #1 on: April 10, 2007, 06:44:51 AM »
generally speaking , the coil thickness is the same as your magnet thickness.
« Last Edit: April 10, 2007, 06:44:51 AM by electrondady1 »
finnsawyer
Re: coils
« Reply #2 on: April 10, 2007, 07:56:06 AM »
Another rule of thumb seems to be that the coil diameter or width is twice that of the magnet diameter or width.  This then determines the rotor size, and given the wire size and number of turns it also, in effect, determines the coil thickness.
« Last Edit: April 10, 2007, 07:56:06 AM by finnsawyer »
hvirtane
    • About Solar Cooking
Re: coils
« Reply #3 on: April 11, 2007, 11:38:18 AM »
The coil size should be such big that the magnet can go inside the coil.
in the above picture the magnets are too near each others. Some people are of the opinion the distance from a magnet to the next magnet should be about the width of the magnet.
« Last Edit: April 11, 2007, 11:38:18 AM by hvirtane »
